How to configure IPAD to connect Wireless (WPA2)
peeravin
Hi Expert,
       I've problem that I cannot configure IPAD connect Wireless LAN (Auth   WPA2)  so I don't know How I have to configure anything on  Wireless Controller or I've to configure anything on IPAD. Please advise me sir.
Best Regards
Peera
7 Replies 7
vinodjad1234
Level 2
Level 2
As I understood , you need configuration on controller side ...  if that is the case... please follow below procedure ..
once you login to controller through GUI ... you need to select " Wireless " option
1) select wlan which you want to configure with WPA2 ...
2) you will get page with all details about corrousponding WLAN
3) select " Security " option in wlan option
4) once you click on security option , you will get option with WPA+ WPA2
5) select that option with what type of encryption you required ...
I believe you need wpa2 with personal edition. if so ... please select PSK with TKIP option .
once you do that , it will be activated from controller side for the respective Wlan ...
About IPAD ... you need to select wpa+wpa2 with psk and TKIP .... I do not have clear idea about IPAD ...
HI expert,
      Do you know what version of IPhone,IPAD firmware can support WPA2 (EAP tls,fast,peap) ?
sorry,
I do not have idea about IPAD firmware .
Hi Expert,
Could you tell me that Which command or tool in wireless controller use for monitor when client try to establish ?
show logging, ....?
thank you very much
login to controller through console or telnet and give below commands
1) show client details < client MAC address >
2) debug lwapp client ?
let me know whether your requirement is fulfilled?
thanks,
vinod
for more info. please go through below link.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080b3e118.shtml
thanks,
vinod
George Stefanick
If you want to do advance security with the iPad you will be required to download the apple utility to open these options.
http://support.apple.com/kb/dl926
Is this what you are looking for?
