How to Create a Heat Map
netops009
Hi.
We have a 2504 wireless controller and eight lwaps but I have no way to create a heat map.  Can someone recommend a good way to do that?
Thank you,
Thomas
George Stefanick
Active heat map is done with site survey software like NetScout AirMagnet Survey.
Thanks, George.  Does Cisco offer something?
Thank you,
Thomas
As far as survey software, no. Check out AirMagnet ..
Roger that.  Thanks, George.
Thomas
