how to create guest access in wireless by WISM and WCS and ACS?
samy.atef
dear sir
i neeed to know the steps of how we can make guest access to our network like hotels by using our WISM v 7.0.220 and wireless control system and ACS ?
Scott Fella
You need to define your requirements a little bit. The WLC can do WebAuth and an employee can access either the WLC or WCS to put in the username and password credentials, but you would need to figure out what's best for you.
Here is a support doc that you can reference.
https://supportforums.cisco.com/docs/DOC-13954
-Scott
