How to disable 802.11b/g radio interface on particular controller managed AP?
iventus82
Hello! We have Cisco 2500 Series controller and 25 AP's. Recently I faced with task of disabling 2.4GHz radio interface only on one specific AP. I found two ways to achive it:
1.     from controller by running command - (Cisco Controller) config>802.11b disable AP01
2.     from AP01 itself by shutting down Radio 0 interface.
But a problem is - after restart of AP the Radio0 interface back to UP.
Anyone have solution for this?
Thank's!
2 Accepted Solutions
maldehne
You need to go to
Wireless --> Access Points --> 802.11b/g/n -->hover the arrow adjacent to the AP you want
click configure
Admin  status --> Disabled
Please make sure to rate correct answers
are you using AP groups with RF profiles ?
what is the version of WLC ?
You may be hitting
CSCug53945    disabled radio is enabled after AP reload when AP group uses RF profile
Symptom:
After AP reload, radio which was disabled before AP reload is somehow re-enabled automatically. This happens when the AP belongs to an RF profile.
Conditions:
AP joins non-default AP group and AP group has RF profile.
Workaround:
Manually disable radio on AP again after reload
6 Replies 6
maldehne
You need to go to
click configure
It was so easy! Thank you very much ) It's also possible to disable specific radio from CLI of controller?
yes ofcourse
config 802.11b disable
Hmm... I chek it right now, and one more time got the same - after restart of AP the Radio0 is UP...
You may be hitting
Symptom:
Conditions:
Workaround:
Yes, the RF profile was the issue. I revert it to none and that fix the problem!
Thank's a lot!
