How to enable debug logs related to Block Ack
We are seeing a strange issue with Cisco AP-2600. While we are running
traffic from our Device to Cisco AP, we see suddenly Cisco AP sends
DELBA.  We are unable to find out reason for cisco doing so.
I would like to know what debugs can I enable to find out the reason? I've already enabled BA under dot11radio tracing. Below highlighted.
I've now enabled below debugs: Can I enable anything else which prints the reason why DELBA was initiated?
on Cisco AP console we see the flood of below messages:  I believe these are coming due to aggregated packets from peer due to delay in Sending DELBA from Cisco & also due to peer side processing of DELBA before aggregation is torn down. But what we are trying to find is, the reason why first DELBA is initiated from Cisco?
<<<<<<<<<<<<<003064 - AMPDU with no ADDBA >>>>>>>>>>>>>>>
ap#show debugging
Dot11Radio 0
   Printing of traces blocked
    Multicasts will be displayed
Dot11Radio 1
   Transmit packet trace will print
   Management packet trace will print
   Command trace will print
   Transmit event trace will print
   Block ack info trace will print
   Transmit fail trace will print
   Client event trace will print
   Psp trace will print
   Other trace will print
    Probe request/responses will not be displayed
    Promiscuously received packets will be displayed
    Ack/Cts/Rts will be displayed
    Crc errors will be displayed
    Beacons will not be displayed
    PLCP header will not be displayed
    IV will be displayed
    CKIP MIC will be displayed
    All RSSI will be displayed
    only last 3 bytes of mac addresses printed
    print time difference between received packets
    4 lines of packet data will be displayed
dot11:
  dot11 virtual interface debugging is on
  IEEE 802.11 packets debugging is on
  Dot11 Mgmt Interfaces debugging is on
  dot11 state machine debugging is on
  Dot11 Stations debugging is on
  Dot11 ssid debugging is on
  Station failed to associate/authenticate debugging is on
  dot11 received packets classification debugging is on
  IEEE 802.11 events debugging is on
0 Replies 0
