How to enable led indicator from console or web panel in WLC 5520?
derobert87
i would like to know if there is a way to trigger blue led indicator from a console or web dashboard of a WLC 5520 device to locate it in rack cabinet?
pieterh
I do not think you can do this from the WLC command-line or web interface
but as this controller  is based on UCS hardware, there must be a CIMC (instant management controller) port on the device
also there is a serial console connector on the device
from the CIMC web interface serial console interface you CAN activate the locator LED.
pieterh
