How to estimate access point for location tracking solution
Espanadroz
I just would like to know how to design for the location tracking solution such as
1. How to calculate AP deployment per sqr m. for accurary tracking ?
2. For the location tracking solution, What we are should be consideration ?
Thanks for your answer
Scott Fella
Have you looked at this guide?  It will explain a lot regarding location:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/wifich2.html
-Scott
George Stefanick
Generally speaking you could use this budgetary models to get an idea equipment wise:
DATA  6,000 sq feet per access point / 100,000 = 16.6 access points
VOICE  3,000 sq feet per access point / 100,000 = 33.3 access points
VOCERA  3,000 sq feet per access point / 100,000 = 33.3 access points
LOCATION   2,000 sq feet per access point / 100,000 = 50 access points
I hope this helps
