How to get 300 mbps on Cisco LAP1142N without WLAN Controller
mustafiz
Anyone using Cisco LAP1142N without Wireless LAN Controller and getting 300mbps throughput? I am only using 5 GHz (Manually Disabled 2.4) but i am getting only 144 mbps max throughtput. It would be great if someone can help me to achive around 300 mbps from this AP.
Thanks in advance.
Leo Laohoo
You need to configure either Open authentication or WPA2/AES to enable 802.11n.
Thanks for your reply. Yes, using Authentication-> open. Under the Radio interface using Channel Width 40-above. Checked with a laptop and it connects with 144 mbps and not getting more then that.
Here is a part of the config:
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$0M/H$HIkGshtMt9w5q.KqNvMQf/asdf
no aaa new-model
no ip domain lookup
dot11 syslog
dot11 ssid TestN2
   authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid TestN2
antenna gain 0
no dfs band block
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel dfs
station-role root
bridge-group 1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
