how to Isolate Guest without Anchor WLC
Freemen
My environment have 1 WLC 7.6, and Cisco ISE 1.3, but guest needed to be Isolated.
Problem now is even I apply ACL_INTERNET_ONLY. when run the scanning tools still able to discover the network segment.
how I can achieve to not allow guest to attempt scanning my network?
Saurav Lodh
Level 7
Level 7
if you can use host discovery scanner which uses icmp ,tcp, udp probes , I think you should check the ACL on WLC once. I will also suggest you to do some packet captures and drill down if any probes present the guest scanner to the subnets.
Stephen Rodriguez
Honestly.....I'd put the ACL at L3 instead of on the WLC.
For ACL on the WLC you have to remember to put your entries in bidirectionally. Allow and disallow in both inbound and outbound directions.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
TQ, let me try out deny the outbound from Private segment
abwahid
Level 4
Level 4
check this configuration example as well.
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/117620-configure-ISE-00.html
