AppleTV and Airplay not working unless I allow P2P
mbecton
I use WLC 5508's and 1142 and 2602 AP's.  AppleTV and Airplay will not work unless I enable P2P on the WLAN ...  We allow BYOD and people are using P2P inappropriately.  Does anyone have any suggestions on how I can get AppleTV and Airplay to work but also disable P2P?
P2P blocking can't be enabled if you want bonjour to work as it is peer to peer. I believe this has been documented in the WLC bonjour guide also. I don't think there is a way to get bonjour to work if you do want P2P blocking enabled.
-Scott
-Scott
5 Replies 5
Rasika Nayanajith
Does AppleTV & clients are on the same WLAN & managed by single WLC ?
Rasika
Yes.. AppleTV and clients are on the same WLAN and managed by a single WLC.  The only way I've been able to get the clients and AppleTV to work is to select the SSID from the WLC then go to ..advanced.. and change P2P Blocking Action from enabled to forward-UpStream.
-Scott
-Scott
Thank you Scott... argh... I agree, but I was still hoping that someone much more knowledgeable than myself could give me a work around.  Take care.
Marty
This document help me a lot:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series-access-point/113443-cuwn-apple-bonjour-dg-00.html
BR
