how to load ap's on dna spaces ?
venkat_n7
I have loaded maps on dna space center and ap's aswell, but not sure how to add those ap's over the map, any idea how i can add access points on dna space maps ?
Please rate comments and support
with regards,
Venkat
Grendizer
You need to have the APs on the maps before you upload them to DNAS then they will show up, there is no manual process for this step. Either this can be by Prime and you need to reupload those maps again with any changes like adding APs, removing APs, changing the location of the APs, in any situation you have to reupload the map again, or you can use DNAC to automate this process.
don.click1
Level 4
Level 4
What about updating coverage zones, inclusion areas, walls, doors, etc? is it the same - edit them in Prime then export/import? is there no MAP EDITOR in Spaces?
