Cisco 9800 WLC Water Sensor
Reid Ditzler
Beginner
Beginner
Have a client that recently had a 9800 controller installed and they are asking for an IoT water sensor. I know Meraki makes a great one but from what I've seen those can only be used if the user has access to a meraki dashboard. This client is using a physical controller non-cloud based.
Can the 9800 be used for this water sensor or is there another one Cisco suggests for this setup of physical controllers?
marce1000
                       >... what I've seen those can only be used if the user has access to a meraki dashboard.
 - If the particular device 'can go wireless' I presume it could connect to APs connected to a 9800 ; the rest and or data handling is for apps ; or else look for similar products on the market with  wireless connectivity.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
WLC 9800 working - we do have some water sensor using Wireless (Hope the water sensor using wifi right ?)
BB
