How to read python script created in guestshell folder on WLC 9800
ahmad.syed
Level 3
Level 3
Hi Team,
We have one python script define in guestshell on 9800 wlc . How we can read what script is created in those directory folder
Seb Rupik
Hi there,
From the CLI you can access bash using the guestshell command. All common linux utility commands will be available. If you know the directory cd into it. Once there use the cat or more command to read the contents of the file.
cheers,
Seb.
nordovv
Visitor
Were you able to find your script? As?
Seb Rupik
Hi there,
cheers,
Seb.
