How to reset a ISE device to factory default?
Ajai Singh
Hello guys,
I just started learn Cisco ISE (TrustSec 2.0), i have my company device which that set on pre-configured configuration from my company meant configured database password.
So i want to ask that how can i reset ise device to factory default configuration.
Plz give me answer as well as possible, thanks in advance.
Scott Fella
Sure...
application reset-config Resets the Cisco ISE configuration to factory defaults.
-Scott
George Stefanick
Scott's on target .. Keep in mind this resets the application the cli still stays intact ..
