How to setting ip address air lap 1262N-A-K9 via CLI?
as my title, can we configure ip address air lap 1262N-A-K9 via CLI?
Thanks for any responses
8 Replies 8
kcnajaf
Level 7
Level 7
Hi Marchand,
Hope this what you are looking for.
AP#lwapp ap ip address
AP#lwapp ap ip default-gateway
AP#lwapp ap controller ip address
AP#lwapp ap hostname
Najaf
Please rate when applicable or helpful !!!
the problem is i cant type any command on cli it's only show log from LAP, so i asked can air lap 262N-A-K9 configure via CLI?
thanks for your response
Do you console access or telnet/ssh to device?
What message do you get when you type above command?
Najaf
i was console the lap, not even can type a single word so no message at all.
Hi Marchand,
That is strange...Have you tried connecting other device console and check if that is working:-)
Najaf
I greet everyone. I have a wifi device, cisco code AIR-LAP1262N-E-K9, but I don't know how to set up wifi password and wifi.mong name of the online community who is using this product please Make a tutorial clip for yourself. I don't have a computer to install with only the phone. hope the community who knows only help me with gmail. my is tienthuy033162@gmail.com thanks to the community
Hi Mai
With those old models you require a Computer with a serial connection and a serial cable. Otherwise it's nearly impossible to configure those old AP models.
Ravi Singh
Level 7
Level 7
These are the command:
you can also check the below link for more detail.
http://www.cisco.com/en/US/docs/wireless/access_point/1260/quick/guide/ap1260getstart.html
