How to SnmpWalk a WLC running SNMP v3? What am I doing wrong...
Rob Johnson
'having syntax difficulties trying to SNMPwalk a WLC with SNMP v3 setup on it
Setttings are::
v3 user is prime
HMAC-SHA Auth Password = BBis123!ATis123
CFB-AES-128 Privacy Protocol = BBis123!ATis123
host 192.168.169.200
ade # snmpwalk -v3 -u prime -l AuthPriv -a sha -A 'BBis123!ATis123' -x AES -X 'BBis123!ATis123' 192.168.169.200
snmpwalk: Timeout
ade #
what am I doing wrong?  ahhhh
Have you enabled SNMPv3 under Management -> SNMP -> General?
Then it should work that way:
schlipp:~ karsten$ snmpwalk -v3 -u zenoss -l AuthPriv -a sha -A zzzz -x AES -X 'xxxx' 10.10.10.220
SNMPv2-MIB::sysDescr.0 = STRING: Cisco Controller
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.1279
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (855721800) 99 days, 1:00:18.00
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Rob Johnson
karsten,
thanks for your response.  i however got all busy today and wasn't even able to look at my controller to see if v3 was enabled or not.....duh, didn't even think of that!!!
i'll take a look 1st thing in AM and will let you know.
Rob Johnson
that was it karsten-
thanks man!!!
sometimes it's that easy ... ;-)
