Showing results forĀ
Search instead forĀ
Did you mean:Ā
How To Upgrade WCS 6 to 7 Versions, Passing By MSE?
I have to upgrade a WCS from version 6 to 7, here we have a MSE having a 6.0.85.0, the matrix document indicates that you can map or well,having installed only one version  or release from MSE to WCS, my question is, DO I HAVE TO UPGRADE FIRST THE MSE TO THE COMPATIBLE VERSION TO THE NEW WCS VERSION WE WANT TO UPGRADE?
Thank you and best regards.
Stephen Rodriguez
from the release notes, it looks as though you may want to upgrade the MSE first.  Or at least transfer the image over, run the upgrade on WCS, then upgrade the MSE.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
