How to use internal DHCP-server on a Wireless Lan Controller?
rayost
I'm trying to use the internal DHCP-server on a 4402 WLC v.7 for air-lap 1141n. But the WLC log says:
*DHCP Proxy DTL  Recv Task: Jan 18 14:51:58.591: c4:71:fe:34:14:c7 DHCP received op  BOOTREQUEST (1) (len 310,vlan 228, port 2, encap 0xec00)
*DHCP Proxy  DTL Recv Task: Jan 18 14:51:58.591: c4:71:fe:34:14:c7 DHCP dropping  packet from AP c4:71:fe:34:14:c7 received on port 2, vlan 228
Here are a screenshot of the ap-manager interface.
http://img46.imageshack.us/img46/8376/apmanager.png
Primary DHCP server is set to management interface (192.168.228.25).
I'm not sure how the Internal DHCP server and ap-manager works togheter, is there a way to connect the DHCP scope to ap-manager?
Thanks!
Surendra BG
The DHCP server information should be filled under MANAGEMENT interfcae DHCP server as well..
that is..
instead of configuring the DHCP server ip on AP-manager, do it on MANAGEMENT interface... check this DOC..
http://cisco.biz/en/US/products/ps6366/products_tech_note09186a0080af5d13.shtml#Internal-DHCP
that is..
Lemme  know after making this changes, this will help you!! and keep in mind,  DHCP AP to get an IP from the WLC = Same VLAN for management and  AP-manager and AP VLAN.
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
I have the same problem.  I have my management set to 192.168.20.6, the ap manager on .8  - this is on a 2125 WLC with 7.0 code.
I can plug my workstation into port 1 and using a static IP, browse to the wlc as expected.  When I plug in an AP to the poe port, the AP never gets an IP.
I created a dhcp scope on the WLC and enabled DHCP proxy.  I consoled into the AP, and get
*Mar  1 00:22:04.506: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP
 address is not assigned or assigned IP is wrong. Renewing DHCP IP.
I have the clock manually set to today's date and time.
I just cannot figure out what I'm missing!
