How to view client statistics on an access point
Michael Murray
Level 2
Level 2
I have Cisco 3602 APs, a 5508 controller, and NCS. I would like to view the client count and client traffic on a particular AP in real time. I know I can view the periodic numbers that NCS pulls but I'd like to see them any time I want. Is that possible?
-mike
ericgarnel
Level 7
Level 7
Enable ssh on the AP(s) and the following commands will provide the info you are looking for:
0 = 2.4 slot  1 = 5 slot
sh controllers dot11Radio 1 wlan
    shows BSSID values for WLANs
sh controllers Dot11Radio 1 powercfg
    shows current and supported power levels for each radio: 0 = 2.4, 1 =5
sh controllers Dot11Radio 0 client | begin RSSI
    shows client RSSI values as seen by radio: 0 = 2.4, 1 =5
    can use pipe to isolate by client mac address
You can enable spin up a linux box with RANCID and use cron to pull the info via script
ericgarnel
Level 7
Level 7
