How to view RF neighbors from AP
nikhilcherian
Level 5
Level 5
Hi All,
Is there a way I can see the RF neighbors from a AP joined with the WLC, can the show controllers dot11radio 0 will help in this
NikhiL
Scott Fella
Well I know the show run-config has that info. The config analyzer might be easier to review since how it's broken down.
Scott Fella
Sent from my iPhone
-Scott
7 Replies 7
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
Thanks Scot, for the help
Stephen Rodriguez
You can do it from the WLC. Go into the GUI, from the main page choose tge radios on the left menu, and pick the particular AP you want to view. When that page comes up switch to text view, should be upper right.
This will show you what neighbors are heard by the AP. this will only show you the Mac address of the AP, not the name.
So if you are looking ti see how OPW ( other people's wireless) is heard you need to do a bit of correlation. Between your AP macs and what's not yours.
Steve
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Steve
I dint get the text view option, which link was that
NikhiL
From the main page on the left Monitor Radio. Pick the radio. From there you should have an option for text view
Steve
HTH,
Steve
Steve,
Got it thanks
NikhiL
Males
Hey guys
I find myself revisiting this old thread tonight and since I found the answer to the original poster's question, I cannot resist but to leave it here, should anyone look for it some day.
You can view this information also by ssh'ing into the AP (AireOS APs here...yes, those ol' guys) and issuing
show capwap rm neighbor-list
It does not display a nice name like 'MyOldAP' but it does give you the bssid...and thus you can figure out who the neighbors are.
Enjoy!
Mae
