how too ??
meggerman
Level 3
Level 3
hi,
i have about 400 ap`s some with CDP some without, how can i apply the CDP setting to all AP`s via my WCS withouh overwriting the individual settings for each ap on antenna,channel,name,power etc..
i.e just activate that setting globally on all AP`s from WCS.
any help ?
cheers
Megz
5 Replies 5
Scott Fella
You should be able to create an access point template and just enable that feature and apply it to the ap's. All other settings will not change.
-Scott
thanks m8,
yes i had worked it out already.. i only applied CDP enabled on the tablet and applied to one controller.. the result was power and channel settings went back to auto ? but CDP was enabled.
strangley even though i have checked my WCS and WLAN for CDP settings and they have all been applied correctly.. i still get a WCS 'false' WLAN 'true' on my audit report next to CDP settings ?
any ideas ?
Is cdp enabled on all th eswitchports?
-Scott
good point !
(goes and checks 🙂 )
have checked, it is.
so im just wondering how my WCS has a different configuration from the wlan controllers 😞
