HREAP losing VLAN mappings (tags)??
rmontoya1058
Has anybody seen code version 5.2 or higher have a problem with HREAP mode APs losing their local vlan mapping and reverting to centrally switched interface vlan tag??
jrodriguez
I have the same problem with 5.1.151 version as a module in WS-C6506-E and a IPservices image 12.2(18)SXF14. It reloads frecuently when I`m configuring it, and some time with out doing nothing. The mapping are losed when the wism reloads.
I have an other WiSM module installed in a 6500 vss and 12.2(33)SXI IOS. The WiSM have the same version 5.1.151 and this one works perfect.
I suspect in a 6500 version, but I still have no time to upgrade
mscherting
Yes, I've seen it a couple of times on APs joined to WiSMs
running 6.0.182.0.  I've not had time to dig into it.  I also saw it this weekend when upgrading a WiSM to 6.0.188.0.
After all the reboots H-REAP vlan mappings were gone; reverted back to a centrally switched vlan.
