Huge DHCP packets between vWLC and switch
DuJin0509
Hello every ,
When I utilize Wireshark to capture packets between vWLC and switch(DHCP server also), I found there are huge DHCP packets transit upon the link between these two devices, actually , this is a lab env , only one DHCP client exist in this env, so it looks impossible to generate so many packets by these two devices. Observed 30 seconds input and output rate almost 13Mbps on switch port .
Any idear for this ? Thank you very much .
5 Replies 5
You have to attach the capture file to see
Rasika
ok, I will upload the capture file at 12:00 am GMT, then please help to check , thank you .
Sorry Rasika
I do not know why I can not upload the capture file , I will check my firewall first.
Hello Rasika,
I upload the capture file now . The file type should be zip
I noticed you have open another thread for the same. I have responded to that
https://supportforums.cisco.com/discussion/13049546/huge-dhcp-packets-transit-upon-vwlc-and-switch
Pls do not open multiple thread for the same
Rasika
