I cant connect AP2702I in Flexconnect mode
dani210867
Hi, I have several ap2702i in FlexConnect mode without any problems, but 1 in particular, connected to a WS-C4506E only works in local mode. When I set the port to trunk (from access), the AP starts to reset without stopping. Some will know why this happens?.
Best regards.
ali aqrabawi
Level 3
Level 3
i'm just guessing :
if you set allowed vlans on the trunk port (not allowing all vlans) , does this issue happen ?
also have you configured the correct native vlan in that trunk port ? so the AP can obtain the right ip address ?
The only diference with others AP's (who are working well in flexconnect) is the Catalyst 4506E.
Port configuration for Local Mode (AP works well)
interface GigabitEthernet2/47
 switchport access vlan 3
 switchport mode access
Port configuration for Flexconnect Mode (AP don't work)
 switchport trunk native vlan 3
 switchport trunk allowed vlan 1,3,8-10
 switchport mode trunk
when the port is configured as trunk are you able to ping the WLC from the AP ?
No, AP not responding till the port is configured as an access again.
