04-10-2025 05:41 AM
Are there any updates to this issue?
%IOSXE-4-PLATFORM: Chassis 1 R0/0: cpp_cp: QFP:0.0 Thread:000 TS:00004305137415759462 %SWPORT-4-MAC_CONFLICT: Dynamic mac xxxx.xxxx.xxxx from GigabitEthernet1 conflict with WlClient, please check the network topology and make sure there is no loop.
Solved! Go to Solution.
04-11-2025 01:11 AM
@hhitalani wrote:
Do you have performance issues?
None whatsoever. Only regular WLC memory leaks which forces me to reboot our controllers (6 x 9800-80, 2 x 9800-40) every 4 months.
04-10-2025 05:43 AM
can these logs affect the vwlc operation or can i just ignore them? i checked the network there is no loop. i need suggestion regarding this
04-10-2025 08:34 AM
- FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt96686
M.
04-10-2025 11:03 PM
I have already checked this case, I have only one 9800cl in my environment.
04-10-2025 09:04 AM - edited 04-10-2025 09:05 AM
You tend to see these when devices roam from one ap to another especially when you have ap's in FlexConnect mode local switching. You can test that yourself when walking around trying to roam and running a debug on your client so you can see where the client is roaming and looking at the logs on your switch. Shouldn't be an issue also.
04-10-2025 11:07 PM
That is right, the logs will appear when the client is roaming from one AP to another. We are currently implementing the local mode, which means central switching.
04-10-2025 03:28 PM
I have seen this error/spam message appear since 17.3.X. Currently on 17.12.4 and the spamming is still present.
I have created a logging discriminator and it helps reduce the amount of this message appearing in our syslog server/catcher.
04-10-2025 11:08 PM
do you use local mode also 9800cl ?
04-11-2025 12:26 AM
Yes. All my APs are local mode.
04-11-2025 12:42 AM
04-11-2025 01:11 AM
06-11-2025 09:12 AM
Would you please share the configuration code of this discriminator with us ?
I also confirm it is still active issue specially with 9800-CL.
All our APs are in local mode with 17.12.x (which is version where this issue should be fixed) and this message is still appearing a lot, since there is a lot of roamings of clients between APs.
06-11-2025 02:54 PM
logging discriminator DNAC_FO facility drops SMART_LIC msg-body drops WlClient|hmac-sha|EPM|dnac
logging buffered discriminator DNAC_FO 40960
logging console discriminator DNAC_FO
logging monitor discriminator DNAC_FO
This logging discriminator is called "<BLAH> fence out" and it should minimize the amount of spam with message body that contains the target words as well as logging facility that contains the line "SMART_LIC".
Hope this helps.
