i'm about to implement ipad to our wireless infrastructure. does anyone know of any settings that i need to configure in 1100 and 1200 access points?
bautistaj
we have cisco 1100 and 1200 aironet access points.  ipads doesnt connect very well...or not stable enough. does anyone know of a config that needed for these access points?
below is a copy of my int dot11 0:
no preamble-short
channel 2437
station-role root
rts threshold 2312
beacon dtim-period 10
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
Leo Laohoo
Awwww ... that's not enough.  Can you post your "sh run" please?
below is the show run...  Thanks.
version 12.4
no service pad
service timestamps log datetime localtime
service password-encryption
hostname AP
enable secret 5 ewrqwrewq@#$#%^%^^^WERq
aaa new-model
clock timezone EST -5
clock summer-time EST recurring
dot11 syslog
dot11 ssid Earth
   vlan 3
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
   accounting acct_methods
dot11 ssid Saturn
   vlan 7
   authentication open
dot11 ssid Jupiter
   vlan 5
   authentication open
dot11 ssid pluto
   vlan 4
   authentication open
dot11 ssid Mars
   vlan 8
   authentication open
   wpa-psk ascii 7 14398274hkjdhfkjqhreqwyflqkjrh
dot11 ssid Voip
   vlan 9
   authentication open
dot11 ssid WiFi
   vlan 6
   authentication open
power inline negotiation injector 081f.f35a.9515
crypto pki trustpoint TP-self-signed-3775118420
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3775118420
revocation-check none
rsakeypair TP-self-signed-3775118420
crypto pki certificate chain TP-self-signed-3775118420
certificate self-signed 01
  30820249 308201B2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33373735 31313834 3230301E 170D3130 30343037 31323437
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37373531
  31383432 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CAAC 1CFAB8E6 EEE31629 804677CF 5B70EB2B 0CCDF4C8 0F235153 DD26584B
  905BE009 446FB229 77FE4931 91AF9DD7 D28791C9 C3A90730 30F2C296 CA4378A7
  155EC70C 73406242 278368A1 1111A56E C95DBBDA 705BABCE 5CA6B295 E1E5B60E
  E9A248DE 5F0D0A4C E57C5F82 B2E1FB64 CEB767ED 9A4979C9 B28E6061 4DFE11B5
  C7890203 010001A3 71306F30 0F060355 1D130101 FF040530 030101FF 301C0603
  551D1104 15301382 114D4143 43482D41 50312E77 666D2E70 7674301F 0603551D
  23041830 168014B2 1343C2BB 6F245A49 6624A07C 2E08D8D1 9E902E30 1D060355
  1D0E0416 0414B213 43C2BB6F 245A4966 24A07C2E 08D8D19E 902E300D 06092A86
  4886F70D 01010405 00038181 001AE89A 468540B0 52C0AB36 EB72C522 E52C6AA5
  05AD61C1 4C2AD7BB 3BA46539 D4D76E96 67FADB5D 34AA48A2 57C3037D 5EEA0AD4
  488F97B1 C2FCE86B B10F7BFA DAFF2233 D603A12A A04F86A9 2255A6FA D00D2A8F
  29289A65 DEB7D6A7 5E9526CD 5100F184 64B521CC 1A121255 C2D2BD20 90F6F55C
  6A8339BD ED0A6DA2 E98DD868 7C
  quit
dot1x timeout reauth-period server
username admin secret 5 $1$U6GV$/em1wwSDFDSAFFAYZN.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 4 key 2 size 128bit 7 dasdhfakdsjhfafjahkfakfakfd transmit-key
encryption vlan 4 mode wep mandatory
encryption vlan 5 key 2 size 128bit 7 dasdhfakdsjhfafjahkfakfakfd transmit-key
encryption vlan 5 mode wep mandatory
encryption vlan 6 key 2 size 128bit 7 dasdhfakdsjhfafjahkfakfakfd transmit-key
encryption vlan 6 mode wep mandatory
encryption vlan 7 key 2 size 128bit 7 dasdhfakdsjhfafjahkfakfakfd transmit-key
encryption vlan 7 mode wep mandatory
encryption vlan 9 key 2 size 128bit 7 dasdhfakdsjhfafjahkfakfakfd transmit-key
encryption vlan 9 mode wep mandatory
encryption vlan 3 mode ciphers tkip
encryption vlan 8 mode ciphers tkip
ssid Pluto
ssid Mars
ssid Earth
ssid Saturn
ssid Jupiter
ssid Voip
ssid WiFi
no preamble-short
channel 2437
station-role root
rts threshold 2312
bridge-group 1
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio0.6
encapsulation dot1Q 6
no ip route-cache
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
bridge-group 6 spanning-disabled
interface Dot11Radio0.7
encapsulation dot1Q 7
no ip route-cache
bridge-group 7
bridge-group 7 subscriber-loop-control
bridge-group 7 block-unknown-source
no bridge-group 7 source-learning
no bridge-group 7 unicast-flooding
bridge-group 7 spanning-disabled
interface Dot11Radio0.8
encapsulation dot1Q 8
no ip route-cache
bridge-group 8
bridge-group 8 subscriber-loop-control
bridge-group 8 block-unknown-source
no bridge-group 8 source-learning
no bridge-group 8 unicast-flooding
bridge-group 8 spanning-disabled
interface Dot11Radio0.9
encapsulation dot1Q 9
no ip route-cache
bridge-group 9
bridge-group 9 subscriber-loop-control
bridge-group 9 block-unknown-source
no bridge-group 9 source-learning
no bridge-group 9 unicast-flooding
bridge-group 9 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.4
no ip route-cache
bridge-group 4
interface FastEthernet0.5
no ip route-cache
bridge-group 5
interface FastEthernet0.6
no ip route-cache
bridge-group 6
interface FastEthernet0.7
no ip route-cache
bridge-group 7
interface FastEthernet0.8
no ip route-cache
bridge-group 8
interface FastEthernet0.9
no ip route-cache
bridge-group 9
interface BVI1
ip address xx.x.xx.xx 255.255.255.XXX
no ip route-cache
ip default-gateway xx.x.x.x.
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip tacacs source-interface BVI1
bridge 1 route ip
line con 0
line vty 0 4
transport input ssh
transport output ssh
line vty 5 15
transport input none
end
