05-11-2017 11:20 PM - edited 07-05-2021 07:00 AM
I have AIR-LAP1131AG-A-K9 equipment.
I do not have a Speed setting for this, so I would like to ask.
Configuration)
Interface Dot11Radio0
Speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
I have applied the above settings. The commands is an input.
However, If I enter show running-config, no information is shown.
Version is 12.4(25d)JA2
I really want to know the cause.
Thank you for your reply.
Solved! Go to Solution.
05-14-2017 12:58 AM
What do you mean by saying you don't have speed settings?
The issue you have is possibly because the command you entered is the default. try to change the speed settings and see if they appear in the config or not.
05-14-2017 12:58 AM
