IAPP
boonteongng
Level 3
Level 3
Is IAPP supported in 350 and 340 AP and PCMCIA cards ?
tepatel
YES..IAPP is nothing but a layer 2 roaming..IAPP accomplishes roaming within a subnet and cisco 340, 350 cards and AP does support that..
But for Layer 3 Roaming (moving from one subnet to another) you need AP1100..
Thanks for the reply.
Any good documentation on IAPP at CCO ?
Can I confirm IAPP is merely for layer 2 roamming ? Layer 3 roaming will require mobile IP ? ( as in AP1100 ? )
Is Mobile IP the only option for layer 3 roaming at the moment ?
Here is the docs which talks about IAPP
http://www.cisco.com/warp/public/784/packet/jul01/techspeak.html
YES..for roaming between subnets, your only choice at this point is AP1100
Here is the url for that
http://www.cisco.com/warp/public/cc/pd/witc/ps4570/ps4612/prodlit/1925_pp.htm
Pl. locate Proxy Mobile IP on that doc.
Is the IAPP used in AP 350, 340 and 1200 proprietary to Cisco ? or is it the 802.11f open standard ?
