IBNS web-based authentication HTTPS intercept
ihornes123
Community Member
Hi everybody,
Hopefully this is an easy question.
I have configured an IBNS setup with Wired Web-Authentication. To sum this up: connect a computer to the switch, go to a web page, the switch intercepts the http request, sends you a log-in page, you log in and get directed to the original web page.
For this, I have used the following guide http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6638/app_note_c27-577494.html
Before I implemented this, I had the HTTP and HTTPS server on the switch disabled. But if I disable the HTTP serer (and leave the HTTPS server enabled), the switch doesn't intercept the web pages anymore. Is there a way to use web-based authentication without using the HTTP server and using only the HTTPS server on the switch?
Hope someone can help me with this.
Ian
0 Replies 0
