Ideal Timeout
saquib.tandel
Level 7
Level 7
Hello
what is the ideal timeout for users when no activity is performed while connected to network via wireless
WLC model 5500
AP model 1200 series
users get disconnected every 15mins when machine is Ideal and where do i see this option
thanks
ST
Amjad Abdullah
The "User idle timeout" value is 300 seconds (5 minutes) by default.
It can be configured from WLC GUI under Controller tab -> General.
or from CLI
(WLC5508) > config network usertimeout ?
      Recommended user idle timeout in seconds between 90 and 100000. Range <15 - 100000>. Default is 300.
Amjad
Rating useful replies is more useful than saying "Thank you"
thanks
what is the session timeout for ?
in WLC
goto WLANs
select SSID
goto Advance
Enable session Timeout
Session timeout is applied regardless of the state of the client if it is idle or not. This is configurable per WLAN. different WLANs may have different session timeout set.
Idle-user timeout is applied to a clients that detected to be idle for the specified period. This is set globally and affect all WLANs.
Amjad
Session timeout is kind of WLAN security feature to frequently check the client authenticity, it forces the client to deauthenticate once it expired so that the client will reauthenticate, it is applicable for L2/L3 security combination and also WLAN with no security.
Wireless client connected AP's Controller will control the user idle & session timer.
In guest anchor scenario both user idle and session timeout is controllerd and managed by Foreign controller. Same applicable In Layer 3 roaming.
