Identifying unpositioned APs on Prime (3.7) maps
joachim68
Hello
Is there a simple way to identify APs which have been added to a map, but have not been positioned yet? Only way I found is to check every single map if there is the blue flag symbol, which indicates unpositioned APs for the map (in case there are any).  As we have hundreds of maps, doing it this way is very time-consuming.
Thanks a lot
Scott Fella
You have to go through each map and look. There is no way to see if the ap is placed and or placed properly.
-Scott
Scott Fella
-Scott
