Impact of a reboot of two WLC 5508 running on verison 8.3.112.0 in SSO mode
thomas.defise
I need to reboot my WLC in order to take count of my new AP license.
Before doing it I need to know what it the impact of a reboot (both)
Also when I do an upgrade, approximately how much downtime is expected?
Thanks in advance for the answer
2 Accepted Solutions
Scott Fella
If your code version is not changing, you can issue a force-switchover which would reboot the active and the standby will become active. Then you wait for the pair to sync and then issue another force-switchover so that the other controller reboots. This way there is no downtime.
-Scott
Scott Fella
-Scott
Thanks for the fast reply.
Thanks for the fast answer, you have an idea of the downtime ?
