Incorrect acces using a customized web authentication page
ithq783ds3
Frequent Visitor
Frequent Visitor
I have a cisco 5508 wireless controller with 7.6.100.0 software version installed. I use the Web Authentication type with default web page that I modified to add my company logo. My problem is that the system only take the username to authenticate the user, even if the password is incorrect. can anybody help find a solution ?
Sandeep Choudhary
means there is problem in html code.
Try to upload webauth bundle provided by cisco and then try to modify it.
From where to download:
http://software.cisco.com/download/release.html?mdfid=282600534&flowid=7012&softwareid=282791507&release=1.0.2&relind=AVAILABLE&rellifecycle=&reltype=latest
Dont forget to rate helpful posts
Sandeep Choudhary
abwahid
Level 9
Level 9
Yes it's better 1st try by uploading the webauth bundle and make customization on it and then try.
