Industrial Wireless AP 3702 WLC Compatibility
omanetcisco
Hi everybody,
I'm working on a new project, I have a 3504 WLC with IW3702 AP, when I check the IW3702 AP data sheet, I don't find the 3504 WLC with the supported WLC.
My question is: From your experience, the 3504 WLC support the IW3702 AP or Not?
Best regards,
Scott Fella
Compatibility depends on the code the wlc is on. You can find the info in this doc:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
-Scott
