Info required regarding Wireless
asim.siddiqui
Visitor
Hi Guys,
Good Day,
I have cisco 4402 Wireless LAN Controller with Cisco Access Point (AIR-LAP1252G-E-K9), everything is running smoothly.
How come i use my Access Points without Wireless LAN Controller, is there any possibility then which AP model would be suitable?
I hope senior will reply me.
Cheers ....
Scott Fella
Are you saying that you don't want to use the wlc? You can always either have the ap in standalone or lightweight in which you need a wlc. You convert the APs by uploading the correct code.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
-Scott
Scott Fella
Now I don't know why you wouldn't want to use a wlc if you have one.... Soooo much easier to manage:)
-Scott
