Input errors and CRC errors on HWIC-AP-AG-A
robdawg01
Visitor
I'm using an HWIC-AP in a 1841 ISR. I seeing crc and input errors on the radio interfaces. Any suggeston on what could be the problem?
bcolvin
Level 6
Level 6
Randell
CRC errors on you wireles system are ususlly an indication of RF interfreence, sources could be Microwave ovens, bluetooth devices, cordless phones, other AP's operating on an overlapping channel, clients broadcasting Probe requests, Wifi printers with the Wifi enabled but not configured,and any other device that operates in the 2.4 or 5.8 bands used by the abg devices.
for wireless systems the CRC errors are common the rule as for all networks is to establish a base line for your environment and then when a problem arises check the current error rate against your base line for a clue as to the source of the problem.
welcome to wireless
Bill
bcolvin
Level 6
Level 6
Randell
welcome to wireless
Bill
Thanks for the response Bill, I thought this could be the case. I'll baseline after a week of operation.
Thanks for the Points
As always it is the client that will determine if the network is meeting their needs.
Bill
