Install and configure AIR-SAP1602E-A-K9 via web interface
kklippenstein
While setting up the AIR-SAP1602E-A-K9 using a web browser, the AP managed to take the IP address of another device.
You will need some type of software to find out what is on your network or be able to get into your router and access the DHCP list and see what is new.  Once you know the IP you can access the AP.
Viten Patel
I would suggest getting console access and checking the IOS version on the AP
aqjaved
Level 3
Level 3
