Integration
tsennett
Visitor
Currently : Using Static WEP
Goal: Provide technology that is both moderately simple to implement and more secure than Static WEP.
I have all Cisco APs. 20 Cisco LAN adapters using LEAP dynamic WEP. I will add 10 hand held devices plus 300 laptops using 802.11 wi-fi compliant non-Cisco NICs.
Can LEAP be used by Cisco and EAP by laptops (XP) and hand helds (WIN CE) ? Can you configure both EAP and LEAP on an AP using the latest greatest firware etc?
ssoberlik
Level 9
Level 9
I don't see support for mixed LEAP and EAP yet. You could use all EAP.
According to Cisco there is the possibilty of mixed 802.1x protocol deployment.
See:
http://www.cisco.com/warp/public/cc/pd/sqsw/sq/tech/acstl_wp.htm
for more info
However I have never implemented this...
