Intel 9560 WLAN and 802.1x
cisco.itsd
Has anyone here had any issues with the Intel 9560 wireless cards while trying to connect to an 802.1x network with certificate?
Using version 20.xx of the driver works fine which goes up to version 20.120. However, something must have changed in version 21.xx as the wireless refuses to connect to the network. Event viewer shows a "wireless security failed" error with reason being that "Dynamic key exchange did not succeed within configured time".
Regards.
eric888888
请问解决了么
Mark Elsen
 - FYI : https://answers.microsoft.com/en-us/windows/forum/all/windows-10-wifi-dynamic-key-exchange-did-not/7a05dd24-5a9b-46bf-af6b-b01391ba270a
 Besides that , how is your cisco wireless  layout ? If you use a controller it is always best to have recent releases , for sufficient windows 10 client connectivity : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html and https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
 Dynamic Key Exchenage may not be related to 802.1x as this can be part of the encryption process.  You can create a SSID based on PSK and see if the same behavior happen. This can halp you narrow down your possibilities.
 In case the problem happen while using PSK, then, your problem can be related to the Access Point and WLC.
JPavonM
Checking Intel Release Notes I can see this:
