interface groups/ap groups for flexconnect
Hi everyone,
I have issue about a SSID mapping multi vlan in flexconnnect mode.
I know there are some method for this:
1\AAA override
2\AP Groups
3\Interface Groups
(pelase tell me if it's wrong).
I want to confirm if  all these method can use for flexconnect to config one SSID mapping multi vlan. Could you help me to reslove this issue?
Thanks a lot!
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Ric Beeching
Level 11
Level 11
If central switching you can override through AAA override and/or AP Groups and/or Local Profiling.
For local Flex switching you can change the default WLAN-VLAN Flex mapping or you can use aaa override based on a number of features. However, note that with FlexConnect you cannot return a VLAN value to the AP that doesn't already exist through a VLAN Template/VLAN Mapping to that AP so it is not 100% dynamic unfortunately.
Ric
Please rate helpful / correct posts
HI Ric ;
Thanks for your repsonse!
As your meaning,we can use "AAA override"\"AP-Groups"\"interface-groups” to make one WLAN map multi vlan if WLAN is centrally switching.But in flexconnect mode,there are some limitation.For example,AAA override 's vlan must be exist in local LAN;for "interface-Groups”,we cannot do it,because we must enable vlan tag,so one WLAN can only map to one vlan.
AP-Groups,Flexconnect AP also support it,so can we create a few AP-Groups,eg:AP-G1、AP-G2 and AP-G3.Suppose we also create some dynamic-interface vlan11、vlan12 and vlan13.We can add AP1-3 to AP-G1 Goups,AP4-6 add to AP-G2,and AP7-9 add to AP-G3.Then,mapping WLAN 2 to interface vlan 11 in AP-G1,mapping WLAN 2 to interface vlan 12 in AP-G2 and mapping WLAN 2 to interface vlan 13 in AP-G3. I don't know whether it will do well.
Best Regards!
