Interface Groups
ajuarez
Level 3
Level 3
Force a device to a specific VLAN when using interface groups. A handful of devices need a static IP
Scott Fella
You can force a device only if your using 802.1x and you are setup to use AAA Override. If its PSK, you can't force them on a specifics VLAN. You might be better off creating a new WLAN and have that only point to a specific interface.
-Scott
