Interference
narayana
Frequent Visitor
Frequent Visitor
What is the main source of interference in access points. Only its from same network or it is possible from the roughe access points also.
What is the suggestible channel utilization percentage in access points.
what is the suggestible interference percentage in access points.
In one case where i am working i found 44% channel utilization and 42% interference how to optimize that.
Leo Laohoo
<65%
Stop using 2.4 Ghz.
But 90% of end user devices are 2.4Ghz band only. This is not quite possible to disable 2.4Ghz
Disable Data Rates from 1- to 11 Mbps. Make 12-, 24- & 48 Mbps as Mandatory and the rest as Supported.
What model(s) are the APs?
