Internet through wireless.
alexageorge
Level 2
Level 2
I am using WLC 4402. The controller comes behind a Nokia Checkpoint firewall. How is it possible to get only internet traffic and not the internal LAN through wireless.
dancampb
Level 11
Level 11
Sure. Easiest way would probably to setup the WLAN to map to a VLAN that only goes through the firewall to the internet. Other options would be to use ACL's, but that will get complicated.
Could you provide me with some configuration examples for doing this by ACL's.
