IOS 5 (IPAD and IPHONE) Authentication issues using LEAP
franklinlopez
Hi All,
We just upgraded some of our devices to IOS 5 (IPAD and IPHONE) and wifi stopped working after we turn on/off the devices. In order to make it work we have to erase and recreate the wireless profile.
Is anyone experiencing this kind of problem?
We are using the below settings
WCS Version:                          7.0.172.0
WLC version:                           7.0.116.0
WiFi SSID:                               XXXXXXX
Broadcast enable:                   No
Operation Mode:                      Network Infrastructure.
Security Settings:                    Enterprise Security
Network Authentication:          Open
Data Encryption:                      WEP
Enable 802.1x:                         Yes
  Authentication Type:             LEAP
  Server type:                           Radius.
Also we found some Apple users having the same, see below the discussion
https://discussions.apple.com/thread/3384783?start=0&tstart=0
Franklin Lopez
mborga
Hola Franklin,
I had also similar issues when I migrated from IOS 4.3.x - to IOS5 in a LEAP-WPA context. I could cirmcumvent the problem by generating a new (Wifi) Connection Profile with the Apple IPhone Configuration Utility and pushing the profile to the IPhone/IPad. By setting up the connection profile on the IPhone/IPad or by taking the migrated profiles I couldn't connect to the Network.
Hope this helps.
Saludos Mauro
P.S.: May be the problem the problem has been fixed with IOS 5.01
We did the same but we still have the issue every 20 min ( disconect)
We are testing with a new ssid
Using wap2 aes peap and broacasting the ssid i think is working so far with iphone
Let's wait for apple with the fix
Sent from my iPhone
