IOS AP and SSID scan
Jan Nejman
Level 3
Level 3
  I have AP with IOS. Do you know how to get the list of SSIDes that AP is receiving (listening)?
I need the same feature as SSID list which you can see when you are connecting on windows.
In better case a list with signal strength. Maybe there is there some monitoring mode....? I tried
show controller dot 0 etc, but without success. It looks that Cisco AP doesn't support this feature.
Kind regards,
Jan
5 Replies 5
Leo Laohoo
Is this what you are looking for:  "sh dot11 bssid"
Don't forget to rate useful ports.   Thanks.
  it is not what I need. This displays only my SSIDes, but I need to get
list of all SSIDes that my AP is seeing/listening. I need to get a rogue ssid
list. In our area, there are many AP (my neighbors). I need to see,
which APes (in my neighborhood) are announcing SSIDed and their signal strength.
The same job do a software tool 'netstumbler'...
Kind regards,
Jan Nejman
How about this:  sh iapp rogue-ap-list
  when I tried the command above, I get an empty list... See the result.
BaseAP#sh iapp rogue-ap-list
IAPP Rogue AP List:
The Rogue AP list is empty
Any other tips?
Kind regards,
Jan Nejman
You'll get better result if you use a WLC.  Without a WLC, how are you going to "triangulate" the rogue AP/Client?  DO you want to contain them?  Without a WLC, how do you expect to achieve this?
