IP address of client and joined access point in WLC
Hey,
How to view IP addresses of joined clients and access points in WLC ? Is there any way ?
Now I'm only stuck with clients IP addresses. I don't find the way to find clients IP addresses. Is there any command in CLI ?
And this is what I've been saying.  If you want a display which shows the client's MAC address, IP address, username, etc (see image below), then the controller firmware version will not support this.  The feature was enabled in 8.0.X.X.  Release Notes for 8.0.X firmware can be found HERE.
7 Replies 7
Leo Laohoo
Yes, use GUI.  On the main page of the WLC, click "Clients".  Depending on the firmware, the IP address of the clients and the AP joined will be displayed.
Hey
In GUI i can see only MAC addresses
See screenshots attached
That's because the WLC is running an OLD firmware.  I believe starting from firmware 8.0 this feature is enabled.
I'm running 7.0.252.0
This is not the issue
I'm now can see the IP address of the APs . I just needed to click on detail (see screenshots)
or > Monitor > statistics > AP Join
hi,
try this command if it's available:
show ap join stats summary all
Thank you. "show ap join stats summary all" is what I was looking for as well.
