IP address problems
teemonahan
Community Member
Hello all,
I have an aironet 350 series wireless card for my compaq iPAQ H3970. It is setup to use a server-assigned IP address but is having problems doing so.
I have looked up troubleshooting documentation for this and a software reset of the device is recommended. This however, does not fix the problem.
I have updated the drivers and firmware so now the ACU uses driver version 2.50.08 and firmware 5.60.08. Does anyone know what the problem might be?
The device connected a couple of times last week but won't connect at all now,
Thanks in advance,
Teresa
b.hsu
Level 11
Level 11
Try replacing with another wireless card to see if that card works, if it works it could be possible that the card is damaged.
