IP Telephony on Wireless Infrastructure
rocampo
Level 3
Level 3
Need expert advise on this setup:
6 Buildings to be connected via wireless using
350 bridges on a Point-to-Multipoint configuration.
Will be running IP Telephony between buildings using
a 2600 router with Call manager express and ATA-186s.
For sure this will run on a LAB setup, but I was wondering if the Wireless Infrastructure would be able to handle this in a production environment.
Comments needed.
trailman73
Level 8
Level 8
Data and voice on the wireless? I would be very hesitant to do this. I have had access points drop when a heavier load is put on them. What distances are we talking? How many people/nodes?
Geoff
aaoybe
Community Member
Im running a solution with 300+ voip peers on a satellite network. It work!
Crucial is QOS and fragmentation. I guess you will have even better condidtions than we have so good luck.
