01-16-2017 12:57 AM - edited 07-05-2021 06:21 AM
Hi all,
Im facing a strange issue with IPAD trying to connect AP 2600 with 15.2(4)JB6 IOS,
the device connects to the AP, gets the IP address, but does not show wifi sign and so internet does not work. Android devices or Laptops dont have any issue.
I tried changing encryption methods with no security , WPA2 withe AES and some others.
Looking out for some help ASAP!!
01-16-2017 01:12 AM
Did you finished with the steps mentioned in the link below ?
https://support.apple.com/en-us/HT204051
01-16-2017 01:22 AM
yes i have already tried this,
even tried it with WLC controlled Access point, it also gave the same result.
01-16-2017 01:49 AM
Which IOS you are using ? Did this happened after updating the device ? also i would recommend removing access password from AP2600 and try to connect IPAD. Lets do this test and decide about it
01-16-2017 03:19 AM
the ios is the latest one in ipad,
this is the first time im trying to connect ipad, but it used to connect to a other cisco AP in other office.
thats why i tried with wlc based ap, but still the issue exists./
02-06-2017 03:10 PM
Did you take a look which frequency band apple device work on ? is that same band enabled in wlc ?
