IPAD Web-Auth after wake up,
fgao
Community Member
                   Many users reported after IPAD wake up , They usually need to do Web-Authentication from Guest wireless network ,
Current , the Guest network is using "passthrough" Web -Auth, and seem this is only happen on IPAD .
I configured " eap bcast-key-interval seconds" to 12 hours, but this won't help ,
Anyone knows what is problem here?
Scott Fella
You need to set the idle timeout to 4 hours or 14400 seconds. That is what I use. I also set the WLAN SSID session timeout to 8 hours or longer, but the session timeout needs to be greater than the idle timeout. The idle timeout setting is in the Controller tab which is default at 300 seconds.
-Scott
Amjad Abdullah
Fan: I fully agree with George. The idle-timeout timer is the timer you need to modify. You set it to a suitable value for your network.
the value of eap bcast-key-interval has no effect here since this only has an effect with users using 802.1x authentication, not web-authentication.
Amjad
Rating useful replies is more useful than saying "Thank you"
